Perform this procedure to apply the Multi-area SPB layer 2 multicast redistribution that you configure in the remote area.
- Select MultiArea
- Select the L2 MC Apply Remote tab.
- In the McastApply field, select apply.
L2 MC Apply Remote Field Descriptions
Use data in the following table to use the L2 MC Apply Remote tab.
| Name | Description |
McastApply |
Applies or disables the Multi-area SPB layer 2 multicast redistribution in the remote area.
